Strange results from DAQ via Labview
Kit: Labview 14 - NI SCB-68 - NI 6255 DAQ
Test: Reading voltages from a force balance in a wind tunnel in wind off then wind on conditions and applying a matrix to give processed force and moment data.
Process: Labview reads the voltages to create a zero file, the tunnel is then started, the software then rereads the voltages and takes off the zero readings to give 'live' readings and, when told, reads the voltages again (and saves as a volts file) then removes the zero voltages, applies the matrix and saves as a processed data file.
Issue: Labview always reads the zero voltages correctly but then reads almost random numbers from that point on in spite of the code being the same.
What's more confusing is it will work for a period (including tests one evening and the following morning) and then suddenly fail, especially as the voltages at the SCB-68 are always correct.
I've tried swopping cables, remaking cables, rerouting power cables, altering the order in which the cables are connected in the SCB-68, rewritten the code and now can't think of anything else to try - hopefully someone on here can come up with something that I've missed
Message 1 of 9
(2,124 Views)
Hi bean,
You missed to attach the code so we can inspect it...
Message 2 of 9
(2,120 Views)
sorry, should be attached now
I'm sure that there are better ways of doing what I need (open to suggestions) but I can't understand how it can work intermittently?
Message 3 of 9
(2,109 Views)
That is not your code. That is a picture of your code with most of the relevant information hidden inside express vis. Please attach your actual vi.
Message 4 of 9
(2,099 Views)
Hi bean,
I asked for code and all I got is an image of code...
What about not using al those ExpressVIs? Their DDT datatype also hides a lot of information behind that thick blue line...
What about implementing error handling?
What about using subVIs?
You may also learn about using proper datatypes, like bundling related values into clusters. Learn to use less or no locals.
Message 5 of 9
(2,086 Views)
ok, should have attached the code now - apologies.
I should also say Labview (or indeed any coding) is not my day job and I'm learning as I go so any advice/pointers greatly appreciated.
Message 6 of 9
(2,078 Views)
Accepted by Littlebean
Hi bean,
I still advice of get rid of ExpressVIs, especially the DAQAssistent.
In my experience it is quite flaky when it comes to continuous operation of longer periods of time...
Example:
Here I just replaced the math ExpressVI and those 5 FromDDT instances...
  • I also recommend to use some (better) code architecture. Even a simple state machine would be much better than your large flat sequence. (Why are there empty frames?)
  • You also should think about code comments!
  • Why does the Acquire button has no label in the block diagram? Would you use variables in a text-based language without giving them a label?
  • You should think about your datahandling! Why do you need to scale the "zero voltages" several times (multiply/divide by 1000)? What about clusters?
  • Does your DAQ device handle all the different sample rates correctly?
Message 7 of 9
(2,046 Views)
thought I'd got rid of those empty frames....will do that now.
can (will) add comments
the scaling is just to make it easier to see on the front screen, it shouldn't be doing that in the final files, will double check that
label added in block diagram now
thanks for all your help
Message 8 of 9
(2,031 Views)
Update: issue has been traced to electrical noise generated by a second pc.................
Thank you for all the help and pointers on how I could improve the code, looks like I have much to learn!
Message 9 of 9
(1,988 Views)
