Stored Procedure
I am having trouble using stored procedures and need some guidance.
If I try to run the stored procedure code I get an error saying I am not providing a required input, but from the LabVIEW it looks like I am providing it.
But I keep getting this error.
The database table looks as follows:
@ID is generated in the procedure, it is looked up and inserted.
I do not have any ability to get into the database myself.  This is a stored procedure writtin by my IT department's DB engineer.  The above image has the required feilds highlighted in yellow that I needed to provide when my code runs.
Can anyone see where my mistake has been made?
Thanks for the feedback.
Ben
(3,639 Views)
Accepted by topic author BenBabb
The procedure isn't going to match up the parameter names with the values you provide.  You only provide 5 params but there are 8 in the stored procedure.  In your case, SerialNumber will be passed into ID, PartNumber into SerialNumber, etc.  Add some blank params in your cluster if they aren't required.
aputman
(3,598 Views)
Actually what i said may not be entirely true.  It depends on the definition of the SP itself.  Your picture just shows a list of the parameters but not necessarily in the same order as defined by the SP.
aputman
(3,589 Views)
Aputman,
Thank you very much.  That is exactly what I needed.  I guess I was confused because my IT Database manager said those values were not required, but LabVIEW must require them.  I put all of the paramaters in and just updated the ones I needed to.  This solved my issues.
Cheers,
Ben
(3,543 Views)
FYI, this is the way that i like to create my parameters.  Hope it helps.
aputman
(3,532 Views)
