Stopping loop when output = 0
so just put both probes on the positive (red) wire?
Message 11 of 16
(1,057 Views)
To test the current the ammeter must be connected in series with the current flow to be tested. To measure voltage the voltmeter is connected in parallel with the circuit being measured.
My guess is that you connected an ammeter in parallel with your battery. That is equivalent to shorting out the battery. NEVER do that!! You could cause the battery to explode. It could destroy the battery, your meter, the test leads, the circuit board in the equipment. This might ruin your day.
If you are not sure how to make these measurements, please consult with a competent engineer for your own safety and to prevent damage to your equipment.
Lynn
Message 12 of 16
(1,057 Views)
so just put the probes on the red wire (positive) wire?
Message 13 of 16
(1,024 Views)
Hi ajsimeon,
You put your probes on the wire you want to measure the current going through. You would need to break/disconnect the wire, so that you can put your probe in series with circuit. See diagram below
Before,
<----------------WIRE-------------->
After,
<------WIRE------><--PROBE-->                 <--PROBE---><------WIRE------>
Stanley Hu
Applications Engineering
http://www.ni.com/support
Message 14 of 16
(1,003 Views)
I am late on the "0" thing but will add anyway....
In 29 years I have never seen an instrument return "0" without something being broke. When it comes to making measurements, "zero is an imaginary number".
Ben
Message 15 of 16
(997 Views)
ok thanks for the replies guys.  i'm getting a reading but for battery testing am I supposed to see the current go down as the battery dissipates or is current supposed to be constant.  or is voltage supposed to be constant.  thanks guys.  learning a lot.
Message 16 of 16
(990 Views)
