Stepping at runtime
I have a program that I would like to pause at each loop iteration and restart at the next iteration using a button.. My test involves relocating a test probe for each iteration. All I see is debugging options which I'm not interested in.
Message 1 of 16
(3,967 Views)
Please, please, please attach your code.
My generic answer to your vague question will be - simply place a breakpoint within the loop, the execution will stop at the breakpoint everytime and you click on the pause exectuion button to continue.
Santhosh
Soliton Technologies
Message 2 of 16
(3,956 Views)
This works. How do I show the block diagram?
Message 3 of 16
(3,941 Views)
A simple Event Structure would work here:
Pressing the button causes the indicator to blink 10 times, otherwise it sits in the Timeout case and waits
=== Engineer Ambiguously ===
Message 4 of 16
(3,923 Views)
This wouldn't work I have a loop with a lot of things happening in it and sometimes I want to run non-stop and sometimes step. My solution works very well. If the Step button is true then it pauses at each iteration, if false, it completes the loop.
Message 5 of 16
(3,917 Views)
I think @   approach would work. That is a fundamental idea. Below is my attempt to build upon @ 's idea.
EDIT: Improvements (disregard the snippet above)
Message 6 of 16
(3,912 Views)
My bad, I misread it.
This also possible with what @ suggested. Check this VI snippet.
Message 7 of 16
(3,888 Views)
Where's the for loop? Can you upload this so I can download it.
Message 8 of 16
(3,852 Views)
I do not recall putting in a for loop. Attached block diagram is a VI snippet, you can save it on your local hard drive and then drag it on to your block diagram and you will have actual coding populate on your block diagram.
But if that does not work. Attached is the VI file.
Message 9 of 16
(3,845 Views)
Well there's the problem, it has to be in a for loop as the program is already built with one and it's too large of a program to make such a drastic change, I think.
Message 10 of 16
(3,837 Views)
