Stepping at runtime
Something like this?
EDIT1: My bad, disregard this reply.
EDIT2: After re-reading your first post and given that your code runs in a for loop and you are willing to step through a for loop which was not in the first post but implied after the last one. Attached VI "Stepping through for loop.vi" should work.
Message 11 of 16
(1,498 Views)
Thanks but could you please give me that vi for version 17?
Thank you
Message 12 of 16
(1,486 Views)
Message 13 of 16
(1,482 Views)
Thanks.
I don't really understand shift registers and never use them. This be off topic but could you explain there use in this case?
Message 14 of 16
(1,472 Views)
Shift registers are used to store/transfer values from one loop iteration to another.
Check out this video by NI:
https://www.ni.com/en-us/innovations/videos/11/labview-shift-registers.html
And training resources:
https://www.ni.com/getting-started/labview-basics/
Is last VI working as per your expectations?
Message 15 of 16
(1,462 Views)
The video was well done and now that understand it a little better, I'll try to incorporate them in future projects.
The last vi seems like it would work if I was to start from scratch but my simple notification works as well and I didn't have to change anything other than add the 2 case structures. I appreciate the lesson though and thank you very much.
Message 16 of 16
(1,445 Views)
