Stepper Motor Speed Record
I am controlling a Phidget stepper motor using the VI captured below which includes a loop. I simply wish to record the speed of the motor as it runs into a text file or similar.
Currently i am trying to create an array and then output that as a file once the loop has stopped. This isn't giving me anything
Unfortunately i have very little LabView knowledge... is there a simple and effective way i could do this?
Any help would be much appreciated.
(2,926 Views)
Look into Shift Registers.
(2,918 Views)
And by the way, your VI was never attached.
(2,916 Views)
Your description of your project was a little vague.  Also, no code/image was posted as was noted above.  And, you do not run stuff into a text file.  You store data in one.  What are you using to record this data?  Are you using a constant for the amount of iterations/samples you wish to take or is this going to be dependent on a User Control?
(2,906 Views)
