Stepped Swept Sine VIs
Where can I find the Stepped Swept Sine VIs?
I want to make a stepped sweep as shown below
(5,484 Views)
Hi gijude,
your image looks like having 3 different sine waves appended to form a big waveform.
Use 3 sine generation functions and append the waveforms…
(5,456 Views)
Use the Generate Sine Wave function inside of a FOR loop.  Just use arrays to pass in the parameters for each sine wave you want to create and using Concatinating Tunnels (new in 2012) for the output array.
(5,441 Views)
Make sure each sine wave represents complete periods so that you have a smooth transition from one sine wave to the next.
(5,431 Views)
I have the same question.
The"Stepped Swept Sine VIs" had been included in "Sound and Vibration Measurement Suite" for a long time.
It belongs to "Swept Sine" palette, and can be found at  Function Palette "Sound and Vibration"->"Swept Sine"->"Stepped Swept Sine VIs" in LabVIEW 2009 to LabVIEW 2012, as shown belows:
LabVIEW 2011 Swept Sine VIs
LabVIEW 2012 Swept Sine VIs
However, the "Swept Sine" palette had been replaced by "Stimulus-Response Test" palette in LabVIEW 2013 to LabVIEW 2015.
LabVIEW 2013 Stimulus-Response Test VIs
LabVIEW 2014 Stimulus-Response Test VIs
LabVIEW 2015 Stimulus-Response Test VIs
But the "Stepped Swept Sine VIs" palette has just disappeared!!
I found one of the SubVI  "SVT initialize Swept sine task " in Help,
But when I click the"find on the palette" link,  the only thing I get is error message:
Also, I can't find it with Quick Drop.
How exactly can I find this palette???
(5,258 Views)
In LabVIEW 2011 with Sound and Vibration Toolkit  installed , I can see this palette:
(5,245 Views)
After consulting NI FAE, I got a temporary solution for this issue.
STEP1: Install Sound and Vibration Toolkit(or Measurement Suite).
If it's installed corretly, you may locate "Stepped Swept Sine VIs" in the path
"C:\Program Files (x86)\National Instruments\LabVIEW2014 \vi.lib\addons\Sound and Vibration\svt_Swept Sine\"
STEP2: Select  "Tools»Advanced»Edit Palette Set"  to display the "Edit Controls and Functions Palette Set" dialog box.
STEP3: Direct to Sound and Vibration->"Stimulus-Response Test" subpalette.
In the last row, you might only see the "Contiunuous Swept Sine"subpalette, but not the"Stepped Swept Sine"subpalette.
STEP4:Right-click an open area on the palette to insert subpalette.
Select "Link to an exiasting patette file (.mnu)"
STEP5: Select  "svt_Swept Sine(DAQ).mnu" and press ok.
STEP6: Press"Save Changes" on the "Edit Controls and Functions Palette Set" dialog box.
And...it's back!
Refererence:  LabVIEW 2014 Manual:  "Editing a Palette Set"
(5,212 Views)
