I've got a two-dimensional array with data stored in each column. Is it possible to get each column of the array separately? It would be like splitting the 2-dimensional array into one-dimensional arrays, so that I can evaluate each column of the two-dimensional array separatel? For example: 2-dimensional array would look like this:
2 5 6 9 3 6 8 10 4 7 8 9
and the corresponding four 1-D arrays would then look like: Array 1: 2 3 4
Use the index array function. As you wire it to your array, it will reshape automatically with two index inputs, the second being 'Disabled index (col)'. If you wire a constant to the second index, you can extract from the array the desired colums (since it is a zero-based index, wire 0 to extract the first column, your 2-3-4 array, 1 for the second and so on). Roberto
Hi marc, find attached VI ... I'm splitting your array in two different ways - one is for separate column computing (index array) and the other for 'loop' related operations. Hope this helps.
