Spikes in Elapsed Time (Variation in Code Performance)
@altenbach
Did you mean implementing a state machine within subVI for saving code?
Message 11 of 16
(1,556 Views)
NO, I mean more like an "action engine". (Sorry for the poor terminology). Yes, everything is in the subVI.
Message 12 of 16
(1,549 Views)
@altenbach
That is interesting. I am not familiar with "action engine" but I will learn more about it and try to implement it in the code. Thank you for the input.
Message 13 of 16
(1,545 Views)
Here's a very rough draft of what I had in mind:
(Very rough! Needs more TLC to be safe to use, so modify as needed. You can use a feedback node (shown) or a shift register in a dummy loop. "Mode" should be a typedef, of course. "Save" is the default, so you typically don't need to wire the mode in the caller)
Message 14 of 16
(1,542 Views)
@altenbach
Thank you, I will look into it. This looks interesting.
Message 15 of 16
(1,536 Views)
Also note that since the ref is kept open, it will keep track of the file position and always correctly write right after the previous data. I would probably turn off "convert EOL", less overhead.
Message 16 of 16
(1,520 Views)
