Spectrum Analyzer N9030A using Labview
I am using MXA series instument driver in labview to talk to PXA spectrum analyzer (N9030A). Am i right on this direction?
I used vi.tree blocks in labview to control central freq, BW, sweep time etc. Everytime I run the program in labview, It changes the values(center freq, bw, sweep time) n that is i want. But it freeze spectrum analyzer and shows yellow solid star in screen. any help?
On my labview program, it shows 0(no error).
(3,908 Views)
Accepted by ghanshyam
Hi ghanshyam,
I assume the driver located here is the one you're using for your device, and it appears that it was tested with the N9030A so it should work.
I did a search through the user manual for your device on the Agilent webpage and didn't see any mention of "star" or "yellow" other than a yellow light that indicates the device has entered standby mode, but that is a LED and not on the actual screen.  Can you perhaps take a picture of what you're seeing, or point us towards a reference in the manual that might show what's happening?
(3,862 Views)
I think I got it working using MXA drivers. I still dont know what that yellow star was. Anyways, Thank you so much for your direction.
(3,855 Views)
