Smart plugs controlled by LabVIEW?
Can anyone recommend a smart plug that LabVIEW can talk to? Either over a wired or wireless network.
Graham
(3,896 Views)
Why don't you do a Web search for whatever you are seeking, and if you can't figure out how to write LabVIEW code to control it, post a more specific question ("How can I control a XYZ-1234 Smart Plug using LabVIEW"?).  You do the "shopping", we'll provide the expertise (if you need it) ...
(3,748 Views)
Hi Bob,
To move this on a bit, I've bought an iBlockcube smart plug - https://www.iblockcube.co.uk/products/m8-wifi-smart-plug?variant=15222745628772
Which uses a WiFi connection after lots of faffing about - https://www.youtube.com/watch?v=12xd5gahxAs
The support is non-existent, but I've tried using this vi - https://forums.ni.com/t5/Example-Program-Drafts/WiFi-Network-Scanning-and-Connecting-with-LabVIEW/ta...
It detects the presence of the device (giving SSID #, Network type: infrastructure, Authentication: Open, Encryption: None), but "Connection failed as no profile was found for the selected hotspot. Profile can be created in the WiFi settings Manage known networks." Which I obviously can't setup for a plug.
Any thoughts? I've only just started playing with this, so apologies in advance if the answer is around the next corner.
Graham
(3,639 Views)
XBee
Never worked with them myself but I read about some old ones many years ago.
Ben
(3,630 Views)
