Single pixel (1px) border missing on LabVIEW windows in Windows 10
Any news about this issue? Will it be fixed in LabVIEW 2020?
Message 11 of 24
(3,243 Views)
Just to make everybody aware, I have raised this question with NI support and they have confirmed that this will be fixed in LabVIEW 2021, however the fix will NOT be applied to any previous versions, so basically any version running on Windows 10 other than 2021 will have the missing border.
What a joke.
So what do I tell my customers who ask why the screen hasn't maximised as they requested and I have to go, well, you see, it is maximised. Makes me (and LabVIEW/NI) look like complete muppets.
Message 12 of 24
(3,089 Views)
First you take a seat, lean back and take a deep breath. Then you count from 1 to 10 and think about how utterly horrendous this situation must be for your customers, who I'm sure have no other problems to tackle than to get upset about a 1 pixel border.
Really, is this something you let your engines get revved up about? Is this worth any high blood pressure and heightened risk of vascular disease? It's a cosmetic bug, and as nice it is to have it fixed, your software is not working one single bit better or worse with this or without it.
NI and most other software providers only backport critical bug fixes to earlier versions, if they do it at all. It's a standard procedure in the industry.
Rolf Kalbermatter  My Blog
Message 13 of 24
(3,077 Views)
What a joke.
Unless it's a showstopper, bugs usually aren't fixed in previous versions.  This goes for pretty much any software that you buy.
What do you tell your customers?  If they complain about it, just tell them it's an evil, soul-crushing LabVIEW bug but you're not willing to shell out $5k to fix it.  Have any customers even complained?  I'm guessing they haven't even noticed.  It's one of those things that you can't "un-see", so I imagine some customer would bring up the topic if it was annoying enough.
BTW - it is a soul-crushing bug.  😄
Bill
CLD
(Mid-Level minion.)
Message 14 of 24
(3,071 Views)
What a joke.
If they complain, invent a workaround...
Message 15 of 24
(3,051 Views)
Definitely not a priority.
21.0.1f1 still does this on Windows 10.
I noticed it today for the first time - now I can't unsee it either. 😞
Message 16 of 24
(2,630 Views)
This is actually a Windows Extended Style problem: WS_EX_CLIENTEDGE
NI added this style to it's panels a few years ago.
Remove it, you will get what you used to have.
When I add this style to Notepad, Notepad has the same problem when maximize.
Use Windows APIs to remove this style at runtime.
Only need to do this once at the beginning of your program.
George Zou
Message 17 of 24
(2,524 Views)
That should be a 10 min fix for NI?
Excl. 5 days of paperwork and testing of course.
Message 18 of 24
(2,481 Views)
Something like this:
Well, you'd need to do this for each VI you want this.
And if you close (not hide or minimize) the FP, you'd probably need to do this again (as you get a new hWnd).
I tried to change this in the LV window's class, but the style of a LVDChild returns 0, so the style is probably applied after VI's FP's are created. So, changing the class's style doesn't result in anything (or I did something wrong, of course).
You could change the VI.NativeWindow method with a FindWindow\FindWindowEx:
But LV titles can be tricky!
Message 19 of 24
(2,460 Views)
And you have just discovered the tip of the iceberg why this is NOT a 10 minute fix. 😀
Windows styles are complicated, involved, interact with each other in difficult to evaluate ways and this even changes between Windows versions. The WS_EX_CLIENTEDGE flag affects how the border is drawn for windows who have one of the other border type flags. For borderless windows it should not have any effect, expect that it seems to somehow offset everything by 1 pixel.
So you may fix the issue of this one pixel white border with your 10 minute fix, but create half a dozen other problems in much less harmless areas.
Also Goerge's explanation that that just was added a few years ago is likely not completely right. This flag was already automatically added to
windows as far back as Windows 95 depending on how they got instantiated and with what other flags. So even if NI would never have added that before it would have been used in many cases in earlier Windows versions. Possibly Windows changed that behavior at some point by not adding it automatically anymore and the quick fix (but definitively more than 10 minutes 😁) was to add it explicitly.
Message 20 of 24
(2,390 Views)
