Single Excel Column Header for Continuous Data Reading
I have been having trouble getting only one header to appear above the excel columns that are being created from my VI. I think the problem is because I am using the running the VI continuously. I need to have it run continuously to keep receiving data. Any help would be greatly appreciated for this new user.
(4,003 Views)
The program does exactly what you tell it do do:
  • Write a header, appending to the existing fie
  • write data, appending to the existing file
None of your while loops serve any function. Why are they there? (They are just glorified sequence frames the way you use them!)
"Run continuously" is a debugging tool, not a way to run a VI, so don't use that. (It just means that the VI restarts from scratch whenever it completes.) Your "submit button will only have an effect if you do it before the 20ms timeout of the event structure. Is this a reaction game? 😮
I would recommend to start with some basic LabVIEW tutorials. All you need is a simple state machine.
(3,983 Views)
Accepted by topic author Hilty
I was able to get what I needed. I am no longer running continuouly from the application, that's what the while loop is for! Thanks for the other tips! I'll post my solution if anybody cares to read it.
(3,971 Views)
You should adjust the logging interval using the timeout value of the event structure, not with a seperate wait.
This is still totally gummed up. If you use a 60 seconds wait (for example) it will take that long until the event structure is ready to fire again. During that time, numerous value change events for the submit button could get potentially queued up.
I still don't understand the "Submit" functionality. How often is this used? It seems to clear the string control. What else? If you would use a latch action button, you would not need to reset it via a local variable. If you want to maintian the regular time intervals for the timeout. you can do that with a little code.
(3,962 Views)
I was just using the "Submit" function to enter any notes during a particular event. i.e. temperature spike or loss of pressure. Most of the time the note section would just be blank.
(3,944 Views)
You read and understood all my concerns, right? They still apply, even after your explanation.
(3,934 Views)
