Simple counter within Control & Simulation Loop
Does anyone know a simple way of creating an incremental counter within the Control & Simulation Loop ? It's not possible to have a For loop within the Control & Simulation Loop hence the shift register method is out.
(2,964 Views)
The "simulation parameters" function on the utilities pallete outputs a "Timestep Index" that is incremented each step. That's the simplest option. Alternatively, you could use a sub VI that executes on major steps and contains a for loop.
(2,953 Views)
