Show data on csv file
How do i read data on a csv file to Thermometer and numeric indicator?
(3,220 Views)
Accepted by Lolnoobie
Read from Spreadsheet File or now known as Read from Delimited Text File
(3,198 Views)
when i try to connect them it say you have connected two terminals of a different types
(3,182 Views)
Hi noob,
Then you need to make both ends of the wire to connect to the same datatype!
My glass ball says you need to use "IndexArray". Let's see how well it was calibrated the last time! 😄
General recommendation: When you have problems with your VI you should attach your VI or atleast a snippet. (Don't post images as we can't debug them with LabVIEW!)
(3,160 Views)
