Short keys for Resize objects menu on front pannel
Hello Guys, does anyone know how to set the short keys for resize objects menu on Front Panel?
This one is used quite often when I design the front panel for User action.
thanks & best regards!
Chris
(1,262 Views)
You can find the short keys for LabVIEW from below link:
https://www.ni.com/docs/en-US/bundle/labview/page/lvhowto/keyboard_shortcuts.html
As far as I can see, I dont see a option to set width and height of control or indicator
CLD Using LabVIEW since 2013
(1,253 Views)
The QuickDrop AlignElements by MNProjects adds this functionality.
https://www.vipm.io/package/mnprojects_lib_quickdrop_alignelements
If you can not measure it, you can not improve it.
- Lord Kelvin
(1,215 Views)
Hello Kelvin,
Thanks for your reply, that's pretty help a lot.
And how about "Resize objects" menu which locate on the right side of align elements?
When I design UI interface, I need to click "set width and height" icon with every control, that's really annoying.
Thanks & best regards!
Chris
(1,201 Views)
Accepted by topic author Chris_Dong
Two options:
  1. Modify the plugin and add to it code to control this. This is actually slightly complicated, as there is no standard way to set the width and height and each class has its own properties for this, but I believe this should be doable with a call to a specific function. See this old example. Note that you have to change the DLL call to point to "LabVIEW", so that you get the correct version of LV.
  2. The LV dialog is actually a VI, so you can just call it yourself, either from that plugin or from another QD shortcut. It's in <LabVIEW>\resource\dialog\Resize.llb
___________________
Try to take over the world!
(1,189 Views)
Thanks a lot, I just take the option 2 and made some modification with resize.dll.
Now it's works well.
Guys, thanks again for all your great support.
Best regards!
Chris
(1,165 Views)
Another option you might like is having a floating VI which will give you access to commonly used tools, which you can activate based on which VI has the focus. See scripting.vit of the scripting springboard for an example of how something like this can work. You might want to enable VI scripting in the LabVIEW options dialog (VI Server page) to get access to more useful features.
___________________
(1,116 Views)
