Shared variable and port forwarding
Hi guys,
I have been working on the shared variable in LabVIEW for a little while. I just encountered an issue with port forwarding of the shared variable. I have been looking for the solution for a while but I have not yet managed to solve the problem.
I have two PCs, a server and a client, and I want to make them communicate with each other over the internet.  It is successful with the shared variable when both of the computers are publicly accessible.
However, for some reason, I wanna put one of the client pc behind a router. In other words, the client pc is in a subnet and the router is publicly accessible.
The solution I found is:
1. Change the setting of the NAT of the router with specific port 2324 for shared variable
2. Add the port to the IP address. For example, 120.157.XXX.XXX:2324
But it did not work for my program and I am not sure the reason why. I wonder whether I used the wrong port for the shared variable. How can I find and confirm the port used by the shared variable in my program?
(3,539 Views)
This Configuring Software and Hardware Firewalls to Support National Instruments Products whitepaper may have your answer...
=== Engineer Ambiguously ===
(3,499 Views)
 Thanks RTSLVU,
I just have a following up question about the ports been used. In the link above, there are multiple TCP ports used by the shared variable. Is there a way that I can find the port been used?
When I mentioned TCP port 2324, I actually mean TCP port 2343.
(3,485 Views)
