CAN FD - Getting only error frames
Hello friends,
Longtime. I am developing a VI for CAN FD with PCI-8512. I am using an existing VI that was used for CAN communication. So I changed the the property of the XNET session node to change it from CAN FD-BRS. I am not getting any error, but not getting any frames on bus monitor either.I checked at the XNET Write, the IO Mode is reading CAN FD-BRS. So I am confused now.  Is there anything else I need to take care of while migrating from CAN 2.0 to CAN FD-BRS?
Arigato.
(3,307 Views)
hi ,i also have simlier problem.  my labview verison is 16, when open bus monitor have error frame, after search i found maybe it is the XNET driver version problem, i'm updating the driver to 17 now, hope it's work well.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P7mDSAS&l=en-US
sushu;
Certified LabVIEW Developer (CLD);
(3,016 Views)
