Setting the value of an array control from ActiveX
When controling a VI through ActiveX, how is it possible to set the value of an array control ?
With numerical controls, I have no trouble: I just use SetControlValue and it works well:
vi.SetControlValue('y', 4) for instance.
However, when trying to do the same with an array, the value of the control becomes an empty array:
vi.SetControlValue('arr', [3 4 5]) for instance.
What is the right way to do this ?
(3,285 Views)
Are you using ActiveX in some other programming language and want to change the array control?
Your notation isn't something I am familiar with.
(3,275 Views)
Indeed, I am trying to set the value of the array control through Matlab. See http://stackoverflow.com/questions/9327101/setting-the-value-of-an-array-control-of-a-labview-vi-thr... for a detailed illustration.
(3,272 Views)
Accepted by calvintiger
Hi Calvin,
Have you tried passing the input as a string and converting it to an array?  You may also want to try using a "matrix" control, rather than an array, as they are handled a bit differently.
Tom L.
(3,246 Views)
