Serial port issue
@alex. wrote:
Yes I close it everytime, and I am using the samle code of 'Basic serial read and write'
It looks like he is just using the built-in example, so we do have his code.
Message 11 of 13
(899 Views)
Thanks Paul,
I initially interpreted that reply as using the "Basic serial read and write" as the building block for his code.
That means the problem is elsewhere (obviously).  We would need to learn more about what is done with the PC prior to running that VI.
So...
Alex,
Have you tried re-booting your PC, and then immediately running the serial VI? (without running anything else prior)  Do you still get an error?
Message 12 of 13
(880 Views)
Thanks for all, after change to another PC, seems not happen.
Message 13 of 13
(864 Views)
