Serial port issue
I need to re-program a serial data receive software by LV, but met the following issues.
1. The original software can initial the serial port successfully, but the LV program some time work, sometime not work. Please see the error message below
2. When using the serial port reading loop, if put no time interval, it seems cannnot receive data.
3. The original program can receive the whole package each time, but the LV program can only receive part of the package each time.
Any suggestion, thanks.
Error -1073807360 occurred at Property Node (arg 😎 in VISA Configure Serial Port (Instr).vi->Untitled 1.vi
VISA:  (Hex 0xBFFF0000) Unknown system error (miscellaneous error).
Message 1 of 13
(5,129 Views)
Alex, can you post your code in here?
It seems like you have an issue with configuring your serial port.  Are you sure the COM port is correct?  The rest of the parameters should be correct as well.
You can't use your port in LabVIEW when you're using HyperTerminal as well.  It doesn't allow sharing of resources
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
Message 2 of 13
(5,126 Views)
With the same configuration, sometime serial  can be initialized, sometime cannot.
How to share the serial port?
Message 3 of 13
(5,123 Views)
And do you close you serial port everytime?
Can you post your VI so we can have a look at it?
Kind regards,
- Bjorn -
Message 4 of 13
(5,119 Views)
You will need to provide more information. What is the instrument you are communicating with? Are you using a driver that you downloaded from NI? Did you download it from somewhere else?
That error code is sometimes returned by the Init functions that exists in instrument drivers that you get from NI. It basically indicates that it could not see the device or could not verify the instrument model. This may be due to lost bytes.
As noted, it would help to see your code.
You can't. The operating system only allows one application access to the serial port at any one time.
Message 5 of 13
(5,117 Views)
Yes I close it everytime, and I am using the samle code of 'Basic serial read and write'
Message 6 of 13
(5,094 Views)
Can I initial a serial handle and read and write in different thread loop individually.
Message 7 of 13
(5,093 Views)
Alex,
That should not be a problem at all.  As long as you know for sure that the port is initialised before you start reading/writing to it.
Kind regards,
- Bjorn -
Message 8 of 13
(5,088 Views)
I'm still not seeing any code.
Message 9 of 13
(5,064 Views)
As smercurio mentionned, you can't.  However, a nice little trick when dealing with the serial port is to query the OS to find out if any other application is using the serial port and if so, to close those applications.
As for your error message, as everyone else has mentionned, we'd need to see your code.
Curiosity question:  What type of serial interface do you have setup on your PC?
Message 10 of 13
(5,049 Views)
