Serial Comm w/Omega
Hi. I'm looking for a serial communications
example vi which talks with an Omega DP41-S
strain gauge. The DP41 uses an RJ11 to
either a DP9 or DP25 pin connector, with
RTS,RX,TX & GND connections. If anyone has
any info they'd like to share I'd greatly
appreciate it!
Thanks, Mary
(3,309 Views)
I have communicated with my DP41-S using Hyperterminal but I haven't found a vi for this purpose.
I need to communicate with a DP41-E also.  So, if you find an answer it should help me out, too.
(3,180 Views)
If you can commuicate through Hyperterminal you can also do it with Labview. Use the Serial Read and Write VIs in the Example Finder.
This should help you out.
(3,165 Views)
