menu ring with variable values and labels
I have a question about using a menu ring with variable “values” and variable “labels”. When I load a “value” combined with a “label” into the menu ring, the first thing I see, in the menu ring, is the “value” number instead of the label. Is it possible to see the first “label” instead of the first “value”.
I attached a simple example of my problem, when you run this example the “value” is visible instead of the label.
Message Edited by Bart L on 03-17-2006 06:09 AM
(2,955 Views)
Hi Bart,
Look at modified version of your VI.
Use shown properties
Regards
Dev
(2,938 Views)
Hi Bart,
I changed it a little bit and it "half-works"...
I let you see what I mean by half-works... I couldn't find an explanation Smiley Indifferent
Hey.... well done Dave, you were faster and more efficient !
Message Edité par TiTou le 03-17-2006 01:26 PM
Epictetus
Antoine Chalons
(2,939 Views)
TiTou,
Merci beaucoup!
Smiley Happy
Regards
Dev
(2,912 Views)
