Sending a floating point through serial using VISA
how do I send a floating point number through a serial port to my microcontroller using VISA Write
Message 1 of 10
(3,562 Views)
How does the micro expect it? You can either typecast it or convert to ASCII string. Pick the conversion that the micro uses.
Message 2 of 10
(3,554 Views)
The microcontroller which I am using takes it as a byte value.
Message 3 of 10
(3,550 Views)
How many bytes? Typecast a sgl or dbl.
Message 4 of 10
(3,537 Views)
okay i got a byte array. Now how do I pass that to the VISA write?
Message 5 of 10
(3,526 Views)
How did you manage to get a byte array from the typecast? I have no idea what you are doing.
Message 6 of 10
(3,522 Views)
OK let's start over. I am trying to send a floating point value to a C program which is expecting it as a 4 byte value rather than as an ASCII string. How can I force the serial port to send it as a 4byte value rather than a ASCII string?
I managed to get a byte array using string -> number function, and then setting it to sgl representation. Is that the right way to do it? Ive added an image for a better understanding
Message 7 of 10
(3,503 Views)
Why are you using a string for the number. Just use a numeric control set for sgl. I already told you to use the typecast function. Why didn't you use that? I've said the same thing three times now. The default behavior for a typecast will convert the sgl to a string that you simply pass to the VISA Write.
Message 8 of 10
(3,499 Views)
Another option is the flatten to string. You can specify the endianess with that.
Message 9 of 10
(3,493 Views)
I would recommend the Flatten To String because of being able to change the endiness.  Some systems want Big Endian while others want Little Endian.  It is best to specify.
GCentral
Message 10 of 10
(3,453 Views)
