Sending a floating point through serial using VISA
how do I send a floating point number through a serial port to my microcontroller using VISA Write
Message 1 of 10
(3,712 Views)
How does the micro expect it? You can either typecast it or convert to ASCII string. Pick the conversion that the micro uses.
Message 2 of 10
(3,704 Views)
The microcontroller which I am using takes it as a byte value.
Message 3 of 10
(3,700 Views)
How many bytes? Typecast a sgl or dbl.
Message 4 of 10
(3,687 Views)
okay i got a byte array. Now how do I pass that to the VISA write?
Message 5 of 10
(3,676 Views)
How did you manage to get a byte array from the typecast? I have no idea what you are doing.
Message 6 of 10
(3,672 Views)
OK let's start over. I am trying to send a floating point value to a C program which is expecting it as a 4 byte value rather than as an ASCII string. How can I force the serial port to send it as a 4byte value rather than a ASCII string?
I managed to get a byte array using string -> number function, and then setting it to sgl representation. Is that the right way to do it? Ive added an image for a better understanding
Message 7 of 10
(3,653 Views)
Why are you using a string for the number. Just use a numeric control set for sgl. I already told you to use the typecast function. Why didn't you use that? I've said the same thing three times now. The default behavior for a typecast will convert the sgl to a string that you simply pass to the VISA Write.
Message 8 of 10
(3,649 Views)
Another option is the flatten to string. You can specify the endianess with that.
Message 9 of 10
(3,643 Views)
I would recommend the Flatten To String because of being able to change the endiness.  Some systems want Big Endian while others want Little Endian.  It is best to specify.
Message 10 of 10
(3,603 Views)
