Selection and Display of Multiple Analog Signals using radio buttons in LabVIEW.
Hello everyone,
I am a beginner in LabVIEW and as a part of a program I'm working on, it is required to capture multiple analog signals (Channels 1~4) from an oscilloscope and display them on a waveform graph where the channels are selected using radio buttons.
The desired operation is as follows:
When Channel 1 is selected, only the waveform of Channel 1 should be displayed.
When Channel 2 is selected, only the waveform of Channel 2 should be displayed.
When Channels 1 and 2 are selected, waveforms of both Channels 1 and 2 should be displayed on the same graph.
And so on.
The problem which I'm facing now is that I get a Timeout Error (Error Code: 1073807339) when I run the VI.
I would appreciate it if you could help me in solving the above issue.
I have attached the VI which I've been working on up to now for your reference.
Software, Drivers and Equipment used:
* LabVIEW Ver.2015
* Agilent 2000 3000 X-Series Driver
VISA Resource Name: USB0::0x0957::0x17A4::MY53160161::INSTR
* Agilent Technologies DSO-X 3034A (Keysight Technologies) Oscilloscope
* SG1638B 2Hz-2MHz Function generator
* Toshiba Windows 10 PC
Please let me know if you need any more information.
Thanks in advance.
(3,075 Views)
Accepted by topic author AzhStark
You can right click on the Plot Legend and choose Visible Items > Plot Visibility Checkbox.
Does that do what you want?
GCentral
(3,071 Views)
Thanks  for the swift response.
It worked!
(3,056 Views)
