Selecting which analog input to plot save
so I have currently a DACmx setup ant this in my VI (part of a bigger setup)
this is currently taking 7 analog inputs. Using 'Mixed Signal Graph' as I will be adding some digital inputs as well.
What I would like to do now is to be able to select what channel(s) out of the 7 inputs is(are) plotted onto the graph and then save the selected channel(s) to file
Any suggestions on how to do that would be done?
(2,799 Views)
Accepted by sherzaad
You should look into a Producer/Consumer setup.  This way your acquisition will be completely separate from your analysis and file I/O.
I would have an array of channels to keep.  So you can just run your data into a FOR loop and use Index Array to keep the channels you care about.
Another note: How fast are you sampling?  You might want to read more than a single sample per iteration of your loop.
(2,776 Views)
