09-15-2017 01:45 AM
Hello can someone please help me with how to select automatically 2 array text files for two different arrays at a single button press.please.
Solved! Go to Solution.
09-15-2017 02:00 AM
Are you talking about a file dialog? How does a single press select two files? Are the two file names static and known?
Please attach some simplified code so we better understand your needs. Thanks!
09-21-2017 02:00 AM
I'm having these two files I wanted to select them at once not one at a time. If I select choose file then I have to select a folder and it will select both of the data at a single click to that folder. Can you please tell how to.
09-21-2017 02:16 AM
Hi Mayur,
When you just want to select the folder that implies there are either (1) just two files in the folder or (2) the file names are fixed and known.
- In case (1) you use ListFolder to get an array of filenames of the files in your folder. As there are just two files you can work with them as intended.
- With case (2) you use the folder path to simply BuildPath with your known file names…
09-21-2017 02:20 AM
Can you please show me this with a vi or photo please.
09-21-2017 02:32 AM
Im having 2nd case
09-21-2017 02:39 AM
09-21-2017 02:53 AM
I've done that before but I can't able to select a folder
09-21-2017
03:05 AM
- last edited on
12-22-2025
08:53 AM
by
Content Cleaner
Hi Mayur,
place a path control.
Right click this control and select "browse options".
Set it to allow only existing folders…
Do you read the LabVIEW help from time to time?
09-21-2017 04:16 AM
this is happening after doing that. I connected a indicator to it and it is reading it there.
