Web browser plugin for Window Enterprise 2007 32 bits running IE9
Hi All,
I have a build application and a HTML page created using the web publishing tool in Labview 2016. I have been managing to display the html on other PCs using Internet explorer, but there's one machine where It wont work. The OS for the PC where I want to display the HTML use window enterprise 2007 and it is 32 bits and runs internet explorer version 9. For some reason the HTML I have wont work on that PC, do I need any specific web browser plugin? is there any incompatibility with that OS?  is there any runtime that support window server 2007? if anyone could please help me to find the answer to those questions I would appreciate it. Thanks!
(2,920 Views)
Have you tried to install the web-browser plug-in version of the LabVIEW 2016 runtime on that computer?
Regards, Jens
Kudos are welcome...
(2,877 Views)
Hi Jens,
I tried that same one you recommended and didn't work, the minimum I'm assuming since that Runtime works for Window server 2008 and higher it must not work for window server 2007, that's why I'm wondering if there's a runtime or if there's a web browser plugin for server 2007, also that one works for 64, I'm looking for 32 bits. Thanks.
(2,870 Views)
