Selecting multiple files by a single Button
Hi Mayur,
your message is like showing a scratch on a car and complaining about "it does not drive"!
To explain the problem you need to provide your VI and tell us exactly the input values you used…
Message 11 of 18
(2,280 Views)
Hi Mayur,
Can you describe really what do you want ?
This error appear when file is not in the path that you specified.
Kudos are welcome Smiley Happy
Message 12 of 18
(2,278 Views)
@Mayur789 wrote:
1505985093091-856571008.jpgthis is happening after doing that. I connected a indicator to it and it is reading it there.
 Need to see code in order to help debug it...
Message 13 of 18
(2,276 Views)
These are my values.1505987494385-1421253687.jpgand this my vi photo sorry my PC is not connected to interet1505987672641-1965943816.jpg
Message 14 of 18
(2,271 Views)
ok Mayur,
If your path is correct (you must verified), add the extension ".txt" to relative path "Voltage" and "Current".
I think that is your problem!
Fred
Kudos are welcome!Smiley Happy
Message 15 of 18
(2,256 Views)
They are in .txt only.
Message 16 of 18
(2,252 Views)
Accepted by topic author Mayur789
In your pictures we can see voltage, Current constant in the relative path.
change this to have Voltage.txt and current.txt.
test it and let me know if you have a new error.
Message 17 of 18
(2,247 Views)
Thank you so much😁
Message 18 of 18
(2,242 Views)
