See the last array value in a loop
Im doing a test VI and to "simulate" sensors im using ULx to have a 2D array and I want to read this data in 4 1D array but I dont want to see all the cells. What I want to see is how each 1D array takes the first value of the respective row and after a delay the next value.
And what I tried to but I dont know how to do it or if it possible it to start again from the first value when the arrays reach the last one, so I dont see 0's.
Thanks.
(1,223 Views)
Accepted by A.Daniel01
You get a 2D array that you convert to 4 1D arrays, do you want to step through these arrays to show each value?
If so, just connect your 1D arrays to a for loop and it'll step through each. Add a Wait if inside you want to see them update.
Qestit Systems
Certified-LabVIEW-Developer
(1,205 Views)
