Searching from excel file
@sam67 wrote:
Thanks for idea but it's little bit difficult for me because i am new in labview. It is possible that you will give me any example if you have similar like this not 100% similar but like this i will try to implement and try to write on this in my current code. Thanks
This isn't really a LabVIEW problem.  It is a general programming problem.  You might be new to LabVIEW, but are you new to programming in general?  Do you know programming logic?  Would you be able to do your task in any other programming language?  Do you know how to write pseudocode or flowcharts to document the thought process and the logic behind it?
If you can, then you are more than half way there and just need to learn what functions and structures are present in LabVIEW.  If you can't do those steps, then you're going to be stuck.
Message 71 of 96
(1,389 Views)
Hello everyone, I am trying to get those rows from the table which is corresponding to the selective indexes. For example, i have one xls file in which different columns of data. currently my code search the selective two columns and their indexes also, know i want to search those selective rows corresponding elements which is in different rows. Lets A B C D E F G are columns name in which 1000 of rows of numbers like A B c D E F G 1 3 4 5 6 3 3 3 4 5 6 3 2 7 ............. 4 7 3 2 5 3 2
So Currently my code search two specific columns (lets suppose B and F selective values which is in some range), now i want to search column A value which is present in those selective ranges.
B F A 3 4 5 3 5 3 7 7 3 5 4 6 ... like this
This is my current code VI
Message 72 of 96
(1,357 Views)
Hi sam,
Your VI will not read XLS files properly - it can read just CSV files…
What are "selective rows"?
What have you tried so far to fulfill your requirement?
After all the discussions in this long thread you still aren't able to create a filtering algorithm on your own?
Your post would greatly improve by using some better formatting (like not writing all text into a single line…). It also would help to supply example data AND the expected output! (Didn't we suggest that before?)
Message 73 of 96
(1,354 Views)
Hi GerdW, I readed your suggestion, and i did that code maybe still i am wrong, but i tried my best to learn this. Well know i just want to search those values which is corresponding to the selective columns. Selective columns (LacI and TetR ) in search strings.
Message 74 of 96
(1,348 Views)
Hi Sam,
"Now", not "know". "selected", not "selective"…
Still no example data.
Still no expected output from the example data.
Still no VI where you try to achieve your requirements…
We will not do your homework!
How do those "values correspond to selected columns"?
Message 75 of 96
(1,345 Views)
@GerdW  작성:
Hi Sam,
i want just this
Message 76 of 96
(1,343 Views)
Hi sam,
you already learned how to read/filter whole columns from a 2D array.
And you learned how to filter parts of those columns by their value.
I don't understand what your current problem is - you already learned those basic steps!
Message 77 of 96
(1,333 Views)
@GerdW  작성:
i tried but i didnt get those value which is corresponding to these selective values. i just need corresponding values of D and J columns.
Message 78 of 96
(1,326 Views)
Hi sam,
First filter for columns D and J.
Then filter for all values in J >= 15.1…
What have you tried? Where are you stuck?
Message 79 of 96
(1,317 Views)
@GerdW  작성:
Hi sam,
for example in column D and J has value 15.63 15.34 15.67 ........, and in corresponding the column C has value 25 24 25 53 22 32 43 25. like this i need these values.
Message 80 of 96
(1,310 Views)
