Searching from excel file
Hi Sam,
so your outer loop should autoindex the values delivered by the inner loop?
Then place the inner loop before the outer loop and use an autoindexing tunnel!
(You should replace the outer WHILE loop by a FOR loop…)
Message 91 of 96
(2,045 Views)
@GerdW wrote:
Hi Sam,
Hi GerdW, can you give me any short example. Thanks
Message 92 of 96
(2,044 Views)
Hi Sam,
simple DATAFLOW and using autoindexing FOR loops:
Message 93 of 96
(2,041 Views)
@GerdW  작성:
Hi GerdW, thanks for example but it doesn't work in my case, here is my code picture.Capture.JPGin this, when 0 plus increment value add and condition is true then just one value passed for further process. Let suppose increment is 5 and final value is 20, then first 5 passed for further process into next loop and then 10 then 15 then 20.
Message 94 of 96
(2,028 Views)
@GerdW
Hi GerdW, I try to implement if condition inside the while loop. My logic is simple, if condition is true stop while loop and store result outside the loop. and if condition is false then stop while and store zero outside the loop. It is working but in both cases it give zero. here is picture of my implementation.
Message 95 of 96
(1,991 Views)
Hi sam,
My logic is simple,
But it seems you are not able to implement a simple logic…
IF "condition is true" THEN "stop while loop" and "store result"
IF "condition is false" THEN "stop while loop" and "store zero"
So you stop that loop independently from your condition: why do you need a loop at all when it will be stopped right after the first iteration???
And why don't you use a Select node instead of that case structure when all you want to do is to select between two possible values?
Message 96 of 96
(1,985 Views)
