Searching Unknown Icon
I'm trying to repeat one example and i can't find this elementt Ð¸ÐºÐ¾Ð½ÐºÐ°.png. It's something like a bounding box.
Best regards
Message 1 of 9
(4,629 Views)
It might help if you tell us which example you're tying to repeat.
Message 2 of 9
(4,618 Views)
Message 3 of 9
(4,607 Views)
If you double click the VI, it should open. In VI Info (CTRL+I) or Save As... would reveal it's path. It's a sub VI of the example, so I'd expect it in a sub directory of the example, or maybe a facilitation directory for all IMAQ examples.
Message 4 of 9
(4,603 Views)
This example on the textbook page. So it 's problem.
Message 5 of 9
(4,599 Views)
Ah, that explains the grayscale image...
I think it simply grows the bounding boxes.
So a Add with a -3,-3,3,3 cluster constant would probably do the same. Or -[1,-1,1,1]X3. Then simply create a subVI from that.
Edit: never mind
Message 6 of 9
(4,590 Views)
What's the textbook about? Does it include a CD or DVD, for example? How old is it?
(Strange code: There is no need for the FOR loop at the bottom, that unbundle could be placed in the last FOR loop.)
Message 7 of 9
(4,569 Views)
About digital image processing and machine vision. Published 2007. Yea it include a DVD but i don't have it.
Message 8 of 9
(4,560 Views)
Accepted by Nadex
That (old) version of IMAQ Rake returns an array of points, whereas IMAQ Overlay Oval accepts a Rectangle, so my guess is that the VI creates a rectangle (square) 3 pixels either side of the point.
Input: [5,15]
Output: [2,12,8,18]
or similar.
It's certainly not a built-in VI, anyway.
Message 9 of 9
(4,529 Views)
