‎02-04-2021
01:48 AM
- last edited on
‎02-04-2021
09:07 AM
by
markwni
I recently installed LabVIEW 2020 SP1, 32-bit, and while trying to run a program written in LabVIEW 2019, I get an error -4600 from a Search and Replace String call.
The error is thrown when the search start offset is negative and the search mode is set to regular expression. I am including an example below... This example does not throw an error in LV2019, but it does on LV2020.
Example snippet
Upon a quick search, I did not find anything in the release notes nor known issues indicating a change in functionality of the Search and Replace String function, other than improvements inserting with Quick Drop.
Is this reproducible and is it a bug?
(If you are wondering why did I wire a negative value, -1, to the search offset, it is because this is the offset past replacement of another Search and Replace String).
Sergio
‎02-04-2021 02:03 AM - edited ‎02-04-2021 02:08 AM
Hi Sergio,
in LV2011 and LV2017 (both 32bit) I don't get an error for your first test case (offset<0, RegEx)…
Maybe one more undocumented change in LV2020SP1?
Sergio, can you change the thread title to include "in LV2020SP1"?
‎02-04-2021 07:09 AM - edited ‎02-04-2021 07:10 AM
LV 2020 SP1 = -4600 unknown error. My guess is that they decided that searching a string outside of its boundaries merits an error now. I wonder if this is because searching outside the boundaries of the string now returns a null character (or characters) which isn't allowed.
‎02-04-2021 08:17 AM
Thanks for the comments... so the behavior is different at least in 2011, 2017 and 2019, compared to 2020.
Hmm.. I don't see null characters at the output... despite the error, it simply returns the original string.
‎02-04-2021 09:02 AM
My guess is that you direct it to search for an offset that is negative, you are searching a part of memory that is not part of the string, itself, so maybe internally it returns a null or maybe since what is outside the memory allocated to the string is unknown, it now simply gives up returns an unhelpful error.
‎02-04-2021 09:04 AM
Oh, ok, yes... now I understand what you meant.
