Scrolling down String programatically
@Ranjeet_Singh wrote:
But I agree INF is better then STRLEN because it doesn't need calculate the strlen in each loop iteration
But can be done using string length. I think using strlen is better then infinite constant?
You seem to be agree on everything.
If you are calculating string length every iteration then why not let constant folding ( using INF ) run its course?
Message 11 of 17
(1,321 Views)
crossrulz wrote:
Did you read the thread that Hooovahh left earlier?  It is Darren, from NI R&D telling us to use it.
Exactly I agree but why it is better then strlen? This is my conern. Moving each time to INFINITY should not be recommeded I think?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 12 of 17
(1,305 Views)
I think INF is better because in each iteration we dont need to calculate string length. From calculation point of view INF is better but according to better way of coding / actual way strlen is better.
Both
--Ranjeet
Message 13 of 17
(1,303 Views)
Both
What does that even mean "better way of coding / actual way strlen is better".  Why do you think using the actual string length would be better than just using infinity?  You are just purely speculating with no reasoning presented to back your opinion up.
I can tell you that using string length is not better because you are using an extra CPU operation to measure the string length.  Now in reality, with modern computers, that is not going to be costly.
You seem to have a habit of making statements, yet continuing to argue that you think you are right, without any valid justifications, even when others point out that what you are saying doesn't make anysense.  It is tiresome.
You've had a lot of contributions to the forums that have helped a lot of people.  But then you occasionally going into these spells where you make these uninformed conjectures that are just coming out of La-La land.  It begins to undermine your credibility.
Message 14 of 17
(1,261 Views)
I said both sounds Ok becuse each one of them have their own pros and cons and also I stated why as I think.
Both
INF-Calculation point of view in each iteration.
STRLEN- Instead of pointing to infinity pointing to valid value is more appropriate(And this works too).
--Ranjeet
Message 15 of 17
(1,252 Views)
Better we stop here. Thanks for your time.
--Ranjeet
Message 16 of 17
(1,251 Views)
INF-Constant that the compiler can optimize how it sees fit usually with constant folding.  Value is just as "valid" as any other number for calculations.
STRLEN-Must be calculated each iteration.
BTW it is tiresome.
Message 17 of 17
(1,236 Views)
