Scrolling down String programatically
I have a string which is updating continously in the fixed interwal. After each interval it will be updated with some new charchers.
Now I want to string scroll down programmatically when new data arrives. But it is not scrolling down.
I tried to simulate same with VI I attched.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 1 of 17
(4,571 Views)
You have to program that. Use the Text.ScrollPos property to set the position of the scroll bar.
Message 2 of 17
(4,559 Views)
Accepted by topic author Ranjeet_Singh
Thanks. I found that already. Along with this string length is what I need.
--Ranjeet
Message 3 of 17
(4,555 Views)
String length isn't needed.  If you always want to do is scroll to the bottom use the Inf constant.
http://forums.ni.com/t5/LabVIEW/Darren-s-Weekly-Nugget-06-28-2010/td-p/1162899
Message 4 of 17
(4,499 Views)
But can be done using string length. I think using strlen is better then infinite constant?
--Ranjeet
Message 5 of 17
(4,483 Views)
Why do you think that would be better?
Message 6 of 17
(4,474 Views)
I think becasue instead of using infinite, using some fixed and valid value is better.
--Ranjeet
Message 7 of 17
(4,468 Views)
Depends what you want.  If you are always going to the end, using INF is by far the simplest, and according the NI, the best way to do it.  There's no need for you to calculate the string length and do weird math that may or may not be quite right.  Keep It Simple Stupid (KISS).
Message 8 of 17
(4,458 Views)
Calculating string length points always to the right place and it is working reliably.
It will be great help to provide some link stating INF is better and why?
But I agree INF is better then STRLEN because it doesn't need calculate the strlen in each loop iteration
Thanks for the concern
--Ranjeet
Message 9 of 17
(4,452 Views)
@Ranjeet_Singh wrote:It will be great help to provide some link stating INF is better and why?
Did you read the thread that Hooovahh left earlier?  It is Darren, from NI R&D telling us to use it.
Message 10 of 17
(4,443 Views)
