How to make stop analog outputting
Hi nice guys,
I'm working on an analog voltage simulation, some signals are longer than half hour, maybe one hour. The function I want to do is, when I click the stop button, the analog output can be stopped immediately. I have no exp. and no idea to make it out.
Thank u in anvance.
best regards
Dai
Message 1 of 9
(3,293 Views)
Just make output 0V, after you pressed stop.
You can do this using the different DAQmx VI's or the not so recommended DAQ assistant
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
Message 2 of 9
(3,289 Views)
how are you generating the voltage?
what hardware are you using?
what did you try? wat it not working in it. can you show it to us?
Learning LabVIEW since January 2013
Message 3 of 9
(3,286 Views)
Care to share what code you have so far?  Are you using any hardware?  If so, what kind?
Message 4 of 9
(3,285 Views)
Hi KoenR94,
thank u for ur reply.
but my VI looks like this,  and it will run once until be finished. I just want to abort the signal output during the outputting.
Message 5 of 9
(3,280 Views)
Message 6 of 9
(3,272 Views)
Hi badstone,
Best is to deliver us your vi.
Because this will make things clear.
Koen
Message 7 of 9
(3,269 Views)
Sounds like you are looking for something like this
Message 8 of 9
(3,257 Views)
Hi crossrulz,
I've tried ur way, but after click stop, it stops only when the signal fully outputted. In my case also
Message 9 of 9
(3,246 Views)
