Scripting: find slide orientation programmatically
Front panel of a VI has a numeric indicator belonging to class Slide (Class ID = 21). Can its orientation (horizontal or vertical) be determined programmatically, i.e. using scripting suctions? Unfortunately I'm out of guesses.
Thank you
_____________________________________
www.azinterface.net - Interface-based multiple inheritance for LabVIEW OOP
Message 1 of 13
(3,703 Views)
You can use the rectangular bounds to see if the width is larger than the height.
Santhosh
Soliton Technologies
Message 2 of 13
(3,686 Views)
Yes, This is what do I use now. However, the method is not general.
For example a very wide vertical Slide can have the width larger then the height. Such a Slide will be detected as horizontal.
Message 3 of 13
(3,682 Views)
Won't work in case you have a tank that looks like this:
Raphaël.
Message 4 of 13
(3,677 Views)
Yes, exactly.
Message 5 of 13
(3,658 Views)
The only way I found was by using the private "Basic Object Flags".
Not sure about the corner cases though:
An officially supported method would be better...
Message 6 of 13
(3,640 Views)
Accepted by _Y_
Raphaël.
That code is risky because the bit definitions are subject to change between versions of LV.  The attached code is much less fragile.
Message 7 of 13
(3,633 Views)
I've not done enough with Scripting to be familiar with "Basic Object Flags".  Am I correct that Paul's "better solution" involves creating two "test cases", a "known horizontal" slider and a "Known vertical" slider and using their (known, and presumably different) "Basic Object Flags" to distinguish Horizontal from Vertical sliders?
Noto to self -- learn more about scripting, which I used many years ago to write LabVIEW code that looked at a 4-Worksheet Excel Template and built LabVIEW code appropriate for using this Template to record multiple trials in a behavioral "Where is the Target?" study.
Message 8 of 13
(3,584 Views)
I would say yes, it is using templates to distinguish between vertical and horizontal slides
Message 9 of 13
(3,555 Views)
to add my 2 cents, we could calculate the eigenvalues of the centered bounding box coordinates of the slide control, because:
- The larger eigenvalue indicates the direction of the longer side. If the larger eigenvalue indicates the variance in the y-direction, then the rectangle is vertically oriented.
- If the larger eigenvalue indicates the variance in the x-direction, then the rectangle is horizontally oriented.
- This is a simplification that assumes the eigenvalues correctly reflect the variance along the principal axes, which is the case for a rectangle with known opposite corners and orthogonal sides
Message 10 of 13
(3,540 Views)
