Scripting: find slide orientation programmatically
@alexderjuengere wrote:
to add my 2 cents, we could calculate the eigenvalues of the centered bounding box coordinates of the slide control, because:
- The larger eigenvalue indicates the direction of the longer side. If the larger eigenvalue indicates the variance in the y-direction, then the rectangle is vertically oriented.
- If the larger eigenvalue indicates the variance in the x-direction, then the rectangle is horizontally oriented.
- This is a simplification that assumes the eigenvalues correctly reflect the variance along the principal axes, which is the case for a rectangle with known opposite corners and orthogonal sides
Is your real name Rube Goldberg?
Message 11 of 13
(807 Views)
Message 12 of 13
(803 Views)
Thank you!
Property BasicObjectFlags works.
At the beginning I tried to get the same information from property Style ID but search for right Style ID (if there is one) takes a hell of time.
_____________________________________
www.azinterface.net - Interface-based multiple inheritance for LabVIEW OOP
Message 13 of 13
(758 Views)
