Script the Removal of a Block Diagram in Memory
@paul_cardinale wrote:
Here's what I ended up with.
Note the Save:ToBuffer method... Saves you a save.
(QD "Save:To Buffer", CTRL+SHIFT+B on a VI method)
Yes, but since this will go in deployable code, I try to minimize my use of brown.
Save:Instrument doesn't work in RTE, at least that's what the documentation says.
Save.To Buffer doesn't mention this... It might actually work better 😊 (probably not).
EDIT: Ah, deployable as in source to customers. Well, if they can see this code, it won't be too useful anyway? If they can't see it, I don't see any objections.
Message 21 of 22
(493 Views)
The code that conceals the BDs doesn't get distributed; but the source code that has some stuff hidden does get distributed.
Message 22 of 22
(483 Views)
