Script for removing comments in entire project
I'd like to know if there is a way to automatically remove all "free floating" comments  in a LabVIEW project and all it's SubVis, ignoring of course the VI lib. I would like it to include comments inside of structures like Case diagrams, Sequence structures etc. By "free floating" I am referring to  comments where you just click on a block diagram and just start typing. Thanks!
Message 1 of 16
(6,263 Views)
I don't think that's a very good idea at all.  The labels weren't put in there because the developer had a lot of free time to waste.  They are there to describe something!  What I would do is handle each free label as you come upon them while you are updating something else.  Don't automatically delete them, but read them and then decide where the label should go.  I can guarantee that you won't want to delete 99.9% of the free labels.
Bill
CLD
(Mid-Level minion.)
Message 2 of 16
(6,216 Views)
Thanks for weighing in. I am the developer in this case. I am well aware of the merits of comments in code. However, it doesn't change my task at hand. 🙂
Message 3 of 16
(6,195 Views)
In anticipation of wanting to delete my personal notes to myself I usually preface them with some searchable string, i.e. *** pwm     (my initials). Then you can use the "Find and Replace". Not sure with other free floating strings.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 4 of 16
(6,182 Views)
@EduNI wrote:
Thanks for weighing in. I am the developer in this case. I am well aware of the merits of comments in code. However, it doesn't change my task at hand. :-).
Comments will not effect the execution.  So,. Unless they are known to be in error, modify but don't delete.  Heck, a good percentage of my bds have a "``" comment
I don't auto tool.  Tab tab sometimes comes out as an unexpected​ comment
Shift 3 works neetly for Putnams notes to self.
"Should be" isn't "Is" -Jay
Message 5 of 16
(6,180 Views)
Accepted by topic author EduNI
While I agree with everyone saying that doing this isn't exactly a good idea...  you didn't come here asking for my opinion.
I believe "Traverse for GObjects" is what you are looking for.  If I recall, the class name for comments is just "Text" - though I also believe this won't catch structure comments.
Unrelated, I've recently become a huge fan of using bookmarks.  I can make notes to myself, keep a clear TODO list, manage my custom error codes, etc.
Edit:  Something like this
Message 6 of 16
(6,155 Views)
If you have a later version of LabVIEW, you can use bookmarks in the future.  Then you can just go and delete the bookmarks when you are done.  I have a ton of #ToDo bookmarks in one my projects, for instance.  😄
Bookmarks are so useful - I've even seen them used as a requirements matrix of sorts.
Sorry about the "words of wisdom" earlier.  If I have no idea of the developer's experience level, I always assume a level of 0.  Your original post sounded like it could've been written by an inexperienced developer about to tie the noose around their neck and jump off the platform willingly.  😉
Bill
CLD
(Mid-Level minion.)
Message 7 of 16
(6,138 Views)
@BowenM can you post as LabVIEW 2015? Although I could manually enter the contents of the For loop quite easily, I am not sure how to get the "All VIs in Project" reference that feeds it.
Everyone: Thanks for all the fervent support of commenting code. 🙂 I feel equally strong in this regard. However, I feel I should explain my need further.  I have a situation where my company is "forced" to give up the code for a project.  We are doing so reluctantly. Since we cannot back out of the agreement we would like to provide the code with as little additional support as we can. We could obfuscate the VI names but that would likely cause additional conflict. And yes, some (not all) of the comments are "#CodeRecommended" and #CodeNeeded" bookmarks from the use of LabVIEW Sample Project code. 🙂   It is not an ideal situation but it is what it is. Thanks again for the support and feedback.
Message 8 of 16
(6,091 Views)
ProjectItems.pngMy better-half used to have a sign hanging in her cube that read...
"Real men don't document. If it was hard to write it should be hard to understand."
Ben
Message 9 of 16
(6,066 Views)
This might be helpful
Message 10 of 16
(6,053 Views)
