Scan from string with delimiter (variable length string)
I know there is a simple answer to this question but I cannot seem to find the solution.
I have an initial string that is delimited by semicolons. I want to extract string "string" into output 1 and floating point number "12.345" into output 2. Since I put the semicolon seperator in the format string you would think it would scan until it reaches that character but instead output 1 is "string;12.345;% and output 2 fails to produce anything.
This format string "%[^;];%f;" will work but seems like a work around to me. Any thoughts?
Message 1 of 10
(9,598 Views)
String length... %<length>s
Period Decimal Separator ( %.; ) before the %f;
Message 2 of 10
(9,586 Views)
Try "not a ;" for your first string. [^;]
Try this in your format string
%[^;];%f;
Omar
Message 3 of 10
(9,563 Views)
TimeWaveZero: The length of the string varies.
Omar_II: I mentioned this in the orignal post but it seems dirty to me. The scan from string functions usually havethe ability to scan a varible length string until it reaches the exact string, which in this case is a semicolon.
Message 4 of 10
(9,557 Views)
Omar_II wrote:
%[^;];%f;
That is exactly what is needed.  The %[^;] will return a string of variable length up until a ";" is found (not including the ";").  It is not a work around.  It is by design.
I highly recommend searching for "Format Specifier Syntax" in the LabVIEW Help.  I keep a printout of that help page hanging in my office since it is such a needed resource.
Message 5 of 10
(9,545 Views)
Accepted by abeaver
Hi abeaver,
ScanFromString scans a variable length string until it reaches a whitespace char (like space, tab, LF, CR)…
Message 6 of 10
(9,543 Views)
GerdW wrote:ScanFromString scans a variable length string until it reaches a whitespace char (like space, tab, LF, CR)…
Wow, I did not know that.  I'm not sure if that is good or not.  I guess it hasn't burned me yet.  But something to keep in mind.
Message 7 of 10
(9,537 Views)
The scan function is what is called "greedy". It will scan using first %s until it finds something that is not a string.
Returning for the first part the longest string the matches. But your string is ALL strings so it grabs all the string to fill the first %s leaving nothing for the rest.
Using Regular Expression there is a flag to make it return the shortest string to meet your format string.
Search for Greedy and non greedy quantifiers.
They might work for the Scan from string function.
I almost never use the Scan from String Function for this very reason. I use Regular Expression so that I can control what I get.
Omar
Message 8 of 10
(9,530 Views)
No need to sell scan from string short.
Message 9 of 10
(9,511 Views)
I have used a cheap brute force method to do exactly this:  Run the string through a search and replace function first, and change every instance of your chosen delimiter(s) to whitespace, then scan from string with the normal format specifiers.
Message 10 of 10
(9,339 Views)
