Scaling 24 bit digital word to real measured voltage on FPGA
Hi All,
i've built a SCTL on FPGA of sbRIO9602 to read digital output of a 24bit ADC..
24 bit word is signed and input voltage range is +-3V, inputs greater than 3V produce digita output of 7FFFFFh and less than -3V of 800000h.
Is possible to build some math with fixed point data format in SCTL of FPGA to realize a sort of direct voltage measurement to show on front panel the voltage that ADC is measuring?
(2,624 Views)
Yes, it is possible and you should be able to find the proper equation in the manual.
However, I would highly recommend against it.  Even thought I knew that it is always recommended to scale data on the host, I tried it all the same in my FPGA code recently.  Result: small bit of code took up 20% of my FPGA.
Scale your data on the host (RT side) and not on the FPGA.
Chris
Certified LabVIEW Architect
Certified TestStand Architect
(2,615 Views)
