3 joints inverse kinematics
Hello
I am trying to built inverse kinematics for 3R joints!
the one aviable on the internet for PUMA is working fine for 6 joints! but when I define my own joints without dynamic properties, the VI executes but doesnot responds when we change the position!
Please ave a look
Sara
(4,075 Views)
Your attachment did not have the kinematic parameters set as default values so I cannot directly look at them. However I suspect looking at your code that you have a arm that can go to arbitrary x,y,z. If so then you want to set the mask to [1,1,1,0,0,0]. Because you have a 3dof arm you cannot converge on all three position and orientation variables so you need to ignore some of them.
(4,064 Views)
I have attached my VI with default values! I am not giving any dynamic parameters to this right now for the time being! I have tried setting the mask values but its not letting me, it changes them again to zero!
Can you please have a look and tell em where I am loosing the track
thanks
(4,038 Views)
I think I didnot put it rightly! how can I use array function to change mask values?
(4,036 Views)
I am attaching a picture in which in i change the input of masking array to 0 and 3, the VI doesnot give error! but when we try to change the coordinates the robot doenot changes its position
(4,032 Views)
Hello
I have changed the mask input to (1,1,1,0,0,0) still its not working, its not giving me joints ouput from the IK VI and thus not displaying any 3D picture
I have attached the changed code please if you can have a look and suggest me something!
(4,004 Views)
Moreover if we stop our while loop VI of FK it gives an error that is related with IK block! the picture is attached
(4,002 Views)
