Save chart data to the file constantly
Yes, I tried that and it gives an error. I discribed it earlier today.
I am now configured the program via DAQmx Configure Logging as
Message 11 of 15
(1,964 Views)
Accepted by AnaKra
Hello
Please see the attached snippet.
 It's based on
Message 12 of 15
(1,947 Views)
Basically, I am trying to achieve a functionality of Signal Express software. However, it also cannot save more than 65000 symbols per text or excel file, but it saves it in graph form so I can go through the whole time while the graph data was recorded. If that saving into the file is a real problem in Labview in any case, then saving a graph data with the possibility of scrolling through it is a solution. Do you possibly have any ideas on implementing that?
Message 13 of 15
(1,910 Views)
Dear Helsinki,
   You really need to attach your VI or Project (if there are multiple files, combine them into a ZIP file).  Many of us stream data to disk in various formats (in my case, I'm collecting 16-24 channels of data at 1KHz on a LabVIEW RT system + asynchronous "Event" data such as digital I/O transitions, TCP-ing it to a PC, and streaming the sampled data in one file and the Event data in a second, .XML, file).  So what you are trying to do is definitely do-able and even simple, but there are Traps for the Unwary.  Without seeing your code, we cannot point out the Traps.
Message 14 of 15
(1,881 Views)
65000 sounds suspiciously like an Excel limitation (a plain text file should work though).  Versions before Excel 2007 have that limit:  https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=excel%2065000%20row%20l...
Message 15 of 15
(1,869 Views)
