Save as PDF
I am trying to save outputs as a PDF file with a password. My outputs are as follows and in top-down order:
  • Header (String)
  • Info (String)
  • Table (String, Double)
  • Extra Info (String, Double)
  • Text (String)
  • Footer (String)
Each section can be longer/taller than a line but will be created within itself, thus a small vi/loop will create the header and wait until assembly and so on.
I have looked into the documentation toolkit but found only HTML, Word and Excel outputs but not PDF, I would like to say that I am trying to perform this task without downloading any add-ons. If you require more information please let me know, will try to give you as much detail as I can.
Cheers,
Diural
Message 1 of 9
(3,525 Views)
Hi Diural,
Create a Word report, then print this report to PDF…
Message 2 of 9
(3,515 Views)
Hey Gerd,
Thanks for answering, but I just can't get a hold of an answer. I have created a word document with string input but cannot find how to just convert it to a pdf and save it as is. I am attaching my vi so far (LV2012). Thank you for the help and sorry for the question which seems like and easy one (not for me).
Cheers,
Diural
Message 3 of 9
(3,485 Views)
Hi Diural,
in the RGT palette you will find a PrintReport function, and there is a QueryAvailablePrinters function. When there is a PDF printer on your computer installed then it's easy to print to PDF.
Another option is to use ActiveX (which RGT is using under the hood anyway) to directly command Word to "SaveAs" PDF document: example found in this LabVIEW board
Message 4 of 9
(3,479 Views)
( ^ emphasis mine)
The report generation toolkit does not support PDF directly. Generating PDFs directly and/or completing PDF forms is possible, but not without additional libraries.
What are your requirements for the password? Printing to PDF is the simplest way to convert a Word (or other) report to PDF, but you may be somewhat limited in the ability to set a password depending on the print driver.
Message 5 of 9
(3,453 Views)
if you have the Report Generation Toolkit (RGT) and create a word report, you can use Darren's nugget (https://forums.ni.com/t5/LabVIEW/Darren-s-Occasional-Nugget-05-13-2014/td-p/2847152 ) to save the report directly to a PDF file.
If you have LabVIEW2015 or later the needed changes are already in the RGT.
UliB
Message 6 of 9
(3,397 Views)
There's also Carya's PDF toolkit.
I haven't used it much but it has more functions than just converting to PDF, might have the set password function too.
wiebe@CARYA knows more about it.
Message 7 of 9
(3,391 Views)
Our production test group uses Exaprom PDF with LabVIEW to print test reports to PDF similar to this example:
PDF Report with ItextSharp
=== Engineer Ambiguously ===
Message 8 of 9
(3,371 Views)
The PDF Toolkit can PW protect PDF's.
Carya Automatisering | Products
Message 9 of 9
(3,343 Views)
