Sand Box has stopped working error when using System Exec.vi with wait until completion is true
I get the following error message in Windows 7 "Sand Box has stopped working" when using System Exec.vi with wait until completion set to true, if I set it to false there is no error message.
Message 1 of 8
(3,362 Views)
Hello JJVerdi
Is this error related to the Cryengine sand box?? If you can you give us more info about your application??
Regards
Mart G
Message 2 of 8
(3,347 Views)
Hi Mart,
The program downloads a hex file to a piece of equipment through an RS485 serial port. I did not write the program but if there is specific information you would need I can ask the software engineer.
Joe
Message 3 of 8
(3,338 Views)
Hi Mart,
This Sandbox has stopped working error message does not appear if I run the software standalone or if I call it using System Exec.vi with wait until completion set to false but I cannot get any feedback from the software if it passes or fails.
Message 4 of 8
(3,327 Views)
Hello JJVerdi
mmm well System Exec.vi simulates a DOS command window, can you run the sandbox from the cmd window using the same commands without any errors?
you may take a look to this KB, it may be related to your issue:
http://digital.ni.com/public.nsf/websearch/2393462BD57B854186256C4F007B706A?OpenDocument
Regards
Mart G
Message 5 of 8
(3,319 Views)
Hi Mart,
The program works fine from the command line.
Joe
Message 6 of 8
(3,313 Views)
Hi Mart,
I tried win16stub.exe and no luck.
Joe
Message 7 of 8
(3,299 Views)
I don't think that KB is quite the issue you are dealing with.
Are you using an antivirus software that sandboxes applications?
Message 8 of 8
(3,286 Views)
