SQLite
I downloaded the files form this page
http://zone.ni.com/devzone/cda/epd/p/id/6287
I am trying to get the SQLite vi's to work under Windows. Has anyone used these particular VI's under Windows?
(3,317 Views)
Using the NI Example finder build into LabVIEW you should be able to find SQL examples.  Make sure that you connect the same, but only use the queries that are supported by SQLite.
Applications Engineer
(3,263 Views)
That version of SQLite was built specifically for VxWorks.  Other versions are built for windows.  I would look for a windows version.  MySQL is also a free version that I would suggest if you don't need it for VxWorks.
Brian K.
(3,255 Views)
