system wide semaphore
This is the only reference I could find on system wide synchronization (i.e. between processes):
  http://zone.ni.com/devzone/cda/epd/p/id/4490
but it seems a bit dated, and one of the comments points to a potential bug.
Should I use the zip file attached there, write my own wrappers to Win32 mutexes, or is there a better library somewhere?
Advance thanks,
(3,084 Views)
The DevZone is a little old, but I just ran the code in LV 2009 SP1 on my Windows 7 machine and it worked just fine.
James West, is correct that the CloseHandle is not called, but I do not know enough about the WIN32 semaphores to know if that would cause an issue.
It would be easy enough though to add a call the the CloseHandle function to destroy the semaphore if you were worried about it.  Just makea new VI that calls the dll and have it run after you hit the stop button.
Justin Parker
Product Support Engineer
(3,045 Views)
I already added the CloseHandle and cleaned up the code a bit.  Haven't tried it yet, though. Still seems that it should be something that LabVIEW should offer, in case one wants to synchronize different executables.
(3,035 Views)
We really appriciate this type of feedback.  We have our feedback page or our new LabVIEW Idea Exchange.  Both get evaluated by R&D and are used to help shape our future releases.
Justin Parker
(3,012 Views)
